It is currently Sat Aug 02, 2025 11:50 pm
PostPosted: Wed Jan 02, 2019 4:57 pm
Cannot for the life of me figure out where it is. I used it after I joined the top to scrape away squeeze out at the seam. Should be on the bench or in a drawer, but I've tore the place apart and can't find it.
It was given me by a friend several years ago, and the only one I had. And that makes it more than just a card scraper to me.
I have been looking on Lee Valley's site.
Been looking at the Bahco, and their Super Hard milled scraper, both of which are Rockwell 48-52.
Anyone have a preference, or another option (around the same price) ?
Thanks.
PostPosted: Wed Jan 02, 2019 5:19 pm
Last Name: Kincheloe
Never tried Bahco, but I do know Lee Valley's super hard type is great.
PostPosted: Wed Jan 02, 2019 5:22 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I have a few Bahco's, they used to be Sandvik.
They're very good IMO.
I'm not a luthier.
PostPosted: Wed Jan 02, 2019 5:24 pm
Thanks, Dennis. l think I'll go with that, then. Same hardness, $4 difference in price.
Thanks, Kevin.
PostPosted: Wed Jan 02, 2019 5:28 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Just hurry up and order something so that you will stumble across the one you have (as soon as you send the order. . .). :)
Bryan Bear PMoMC
PostPosted: Wed Jan 02, 2019 5:31 pm
Yes, hahaha! I would consider that a win.
PostPosted: Wed Jan 02, 2019 7:46 pm
Some people make card scrapers out of old handsaws. If you have one beyond fixing it might be a good candidate,
PostPosted: Wed Jan 02, 2019 9:28 pm
Yes, I tried that. The only thing I had to cut it was an angle grinder. Can't get straight cut, so only the one straight edge from the spine side. Will use that if I must, but it looks like crap.
PostPosted: Wed Jan 02, 2019 9:30 pm
Tried Wiss snips, but my hands cannot deal with trying to cut it with those.
PostPosted: Wed Jan 02, 2019 9:49 pm
You need a DMT Dia-sharp extra-extra-coarse stone, then :) I find endless uses for mine. Straightening up a rough angle grinder cut would be a piece of cake. Lee Valley used to have the best price on them, but looks like Amazon is by far the best now at $75.
PostPosted: Wed Jan 02, 2019 9:53 pm
DennisK wrote:
You need a DMT Dia-sharp extra-extra-coarse stone, then :) They're a little pricey, but I find endless uses for mine. Straightening up a rough angle grinder cut would be a piece of cake.
I have a coarse Aluminum Oxide stone. Might try that. Can't hurt.
PostPosted: Thu Jan 03, 2019 1:02 am
If I were to get a new scraper, I'd be getting one of these...
https://www.stewmac.com/Luthier_Tools/T ... raper.html
PostPosted: Thu Jan 03, 2019 6:58 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We have the old Sandvik, newer Bahco version, the Lee Valley superhards, the Lie-Nielsen set (thin and thick), and dozens of purpose-made scrapers made out of old Disston saw plate. The Lie-Neilsen thick sees the most use, with the old Sandviks a close second. I don't really care for the superhards or the new Bahco, although both are well milled and don't seem to require all that much work to put into service.
Old, damaged saws work well for smaller specialty scrapers- we hacksaw and disk-sand to shape, and they hold a decent edge. Cut close to the final shape with hacksaw and work to the line with a fresh 10" mill bastard, then stone and sharpen.
- Beth Brower
PostPosted: Thu Jan 03, 2019 7:06 am
+1 Of all the scrapers I have, the StewMac versions are the only ones I use anymore.
PostPosted: Thu Jan 03, 2019 7:23 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I have cut scrapers from old saw plates by filing a line with a 3-corner file, then snapping it off, then filing the edge smooth. Just takes a minute.
Ed
These users thanked the author Ruby50 for the post (total 2): Bryan Bear (Thu Jan 03, 2019 8:41 pm) • Mike Baker (Thu Jan 03, 2019 8:17 pm)
PostPosted: Fri Jan 04, 2019 12:28 pm
Well, I persevered, and went with the ones cut from an old saw plate.
They are not pretty(which seems to be a theme for my shop made tools), and they aren't square on the ends, but the long ends are dead flat. I don't generally use the smaller ends.
And they are sharp enough, I think. Here's a bit of a test in some Indian Rosewood.
Works for me.
Thanks for all the replies and advice.
Much appreciated.
These users thanked the author Mike Baker for the post: Bryan Bear (Fri Jan 04, 2019 12:31 pm)
PostPosted: Fri Jan 04, 2019 1:31 pm
Last Name: Livermore
State: Minnesota
As long as you are making scrapers, and seeing as you have a good supply of old planes, I will suggest making yourself a Carruth style scraper.
StewMac sells them. But I made one myself (before buying the real thing) by grinding the edge off an old block plane blade, turning it on it's side and sharpening it as I sharpen the Carruth scraper on the grinding wheel.
For the ten bucks or less I get block planes at swap meets and antique shops, it is well worth it. The old USA steel is pretty hard stuff and makes for an awesome tool.
When leveling rosettes and binding and purfling, I find I can never have too many tools handy. Whether a card scraper, plane blade scraper or Carruth scraper, they all have their uses.
dl
PostPosted: Fri Jan 04, 2019 1:51 pm
Dave, thanks. I have a couple blades laying around.
When I get to the point of owning a bench grinder, I will most definitely do that. It looks like a great tool to have.
PostPosted: Fri Jan 04, 2019 8:31 pm
Last Name: Minch
City: Chestertown
Is that Carruth blade sharpened to be hollow in the center of the edge and pointy along the cutting edges? Is there a hook on it?
Ed
PostPosted: Fri Jan 04, 2019 8:50 pm
State: Minnesota
Hollow, yes. Hooked, no.
Here is a link to the productat Stewmac. At the bottom of the page is a video of Al Carruth demontrating it. Below that is sharpening instructions.
https://www.stewmac.com/Luthier_Tools/Types_of_Tools/Scrapers/StewMac_Ultimate_Scraper.html#product-instructions
Hope that helps
PostPosted: Sat Jan 05, 2019 4:55 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
+1 on recommending the Carruth scraper from StewMac. I haven't used any of my card scrapers (and I have a few) since I got one of those.
But nice job on the saw recycling Mike. I love seeing an ugly but effective tool made from scrap.......
PostPosted: Sat Jan 05, 2019 7:20 am
First name: Willard
Last Name: Guthrie
City: Cumberland
We have two of the Carruth scrapers in the shop plus a few shopmade thick scrapers used with the edge off the grinder, and they see use on archtop body and binding repair. That said, standard card scrapers are the more flexible tool for us - properly sharpened, the cut may be adjusted from micro-fine to coarse, and the flex in the thinner scraper blades can be useful when working some surfaces.
Card scrapers are much faster to sharpen for coarse work than the Carruth scraper, but are harder to learn to sharpen and set well for fine work...my learning curve on card scraper sharpening and use was much, much steeper than with any other hand tool routinely used. Coarse work - such as scraping down binding and purfling - can be done with a card scraper filed and burnished (a 30 second job...maybe a minute in total to knock the old edge off, roll the hook, and back to work). Fine work really begs that the edges be stoned before a careful burnish is done and hook rolled onto the edge, and it takes time to do that job.
When we have a job that calls for one of Mr. Carruth's scrapers or our shopmade versions fabricated from the old straight jointer blades - rebinding a 1960's Gretsch Country Gentlemen comes to mind - we leave the CBN wheel on the grinder set up with the guide square and touch up as needed. If we could fit in a 3rd low speed grinder, I think we'd likely leave one set up with a 220 grit CBN wheel/squared support just for touching up thicker scrapers.
- Beth Brower
PostPosted: Sat Jan 05, 2019 10:34 am
Thanks. That pretty much describes any tool I make, lol.
PostPosted: Sat Jan 05, 2019 7:32 pm
Last Name: Minch
City: Chestertown
Dve
Thanks for the Carruth video - explains his idea very well. I have a couple of old floor scraping blades that are a full 1/16" I might try this with
Also, my floor finisher friend sold me a bunch of his tools when he retired. One item is 14" long burnisher. In the 50's he ordered a couple of Nicholson files fully hardened with no teeth. Ha had an unused one he sold me - pretty cool item.
Ed
